5 gear popping out!
malin819
53
May 29, 2012
ottawa, QC, Canada
Whenever I put my car in 5th gear, It just pops out
I took the case and saw that the nut was loose but I need a new nut. Where can I find the nut on the end of the shafts. Its a common problem...the one I have is cracked and I want a new one im.clueless where to buy!!
Which nut are you talking about? 95% of the time, if the bolt has an 8mm shaft, it is a 8 x 1.25 nut, 10mm shaft, 10 x 1.25, and 12 x 1.25. You should be able to find them at your local hardware store with the rest of the metric hardware.
What size head does it have?
I have no idea what you just asked...alll I know its the upper shaft nuts that needs to be replaced.
Also, a gold ring fell with teeth fell off from there...do o just put it back on because nothing is reall holding it down.
Are you familiar with how metric nuts and bolts work? Lets say the shaft is 10mm across. It can be 10 x 1.5 or 10 x 1.25. The second number refers to the size between threads.
I'm not really sure what nut you are talking about? is it in the engine bay or in the center console?
Ok good thanks guy!!!
Yeah its that ring but there is also a half circle thing that was held on with 3 teeth..now its loose and in my hand
Jacks Transmissions LLC — Synchro Spring (Small)
I have that piece in my hand
Jacks Transmissions LLC — 3-4 Synchro Key
Are thosr suppised to be tight? They were holding the reverse spring into place. Can i just pop it back in and manually put the stoppers with a litgle srew driver?
Their Is a key spring below the 5th gear hub as well. I am assuming you shifted the car with the end cover and blocker ring out to have them pop out. Try to squeeze them back in but make sure you get the spring locked in right. The dimple in the spring will lock into the back of one of the keys. Then the Top Key spring goes on then the blocker ring
Yup.
There are 2 synchro springs holding the keys. There is also a wave spring on the end cover. See my thread for details. Contact Jack at Jacks Trans and he'll set you up with what you need.
