4th Annual Northeast DSM Meet - Parts Swap Thread
snowborder714
Moderator
16,188
461
Oct 15, 2006
Mechanicsburg, Pennsylvania
For anyone coming, you can use this thread to say what all you'll be bringing and/or what you'd be looking to pick up. It'd probably be easier if you made one post that contained all of this info vs. making a new post each week saying "Oh, I found this and will have it as well". This will make the thread cleaner and easier to navigate.
WTB:
2gb Talon Front Bumper in good condition
2g Aluminum Radiator
Front Passenger and Rear Driver ABS sensors. The front should be the same for all 2g's. The rear may be 2g AWD specific.
FS:
TBA - If you need random stock parts, let me know and I'll make a trip to the local salvage yard to pull some stuff.
I have a bunch of OEM engine parts. Pm me with info of what you are looking for. I do have 2 bare 7 bolt blocks (no cranks) I'll bring only if there are interested parties.
I have a 2g aluminum rad with 2 12" slim fans, spearco fmic/piping/authentic hks ssqv if anyones interested.
I will be bringing some tanks for people to look at in person.
Parts that i have available. I'll try to bring everything left since I'm moving soon.
1G PARTS
cylinder head with valves, springs, retainers and keepers installed all but one that is included, also have cams and caps etc. * black 7mm spark plug wire set in good shape(went 11.7s on them @120mph) * stock '92 turbo oil filter housing assembly * OEM throw out bearing with about 5,000 miles * waterpump pulleys * N/T crank pulley/dampener in good shape * N/T hydrolic Tbelt tensioner * '92 turbo water pipe that goes from waterpump and runs behind exhaust manifold * dip stick tube and stick * N/T oil pressure acorn * 4G63 6bolt t-belt tensioner bracket &pulley with bolts * 1Gb black hook good-fair condition * donut wheel and tire * 1G turbo o2housing * A/C fan assembly * center dash vent * rear seat belt assemblies * battery hold down w/ straight bolt only * A/C tensioner assembly
2Ga TURBO PARTS
Air bag from steering wheel * '96 turbo cam gears with bolts * 2Ga reverse lights * starter assembly w/ harness * waterpipe from waterpump that runs behind exhaust manifold * t-belt tensioner bracket w/o bolt with pulley mounted * t-belt hydrolic tensioner * good crank pulley/dampener in good shape with 4 bolts * fuel rail * driver's side lower window trim good shape * MPI transistor thing * driver's side inside door handle (opens door from inside) * teal fuel door good shape * grey ashtray * power steering pump w/o pulley * driver's side window glass
OTHER DSM PARTS
2G sized t-body elbow * anodized black vacuum block with fittings * aftermarket black shift knob with "+"cross on top * stock replacement front engine mount for 1G 4G63 new in box * Geo Metro mini radiator and fan assembly with hose and rad cap.
Any questions just PM me. Thanks for the space.
WTB:
  1. Free or dirt cheap 2g maf that is intact but can be dead
  2. Driver side, BLACK, rear speaker grill with no broken tabs
  3. I'm looking for connectors for the 'Oil Pressure Switch (Dummy Light)' or 'Engine Coolant Temperature Gauge Unit' with a bit of GOOD wire on them, either connector will work:
    http://www.dsmtuners.com/forums/151542327-post50.html
    http://www.dsmtuners.com/forums/151542275-post38.html
  4. Also looking for the piece on the 'Oil Pressure Switch (Dummy Light)' that the connector plugs onto - it's screwed into the sensor. Either 1g or 2g will work - I just need the part the connector goes on, not the whole sensor.
I'm looking for a bunch of these for a wiring project so let me know what you have.
F/S
PTE 50 trim turbo in a good condition (don't know serial number of it)
FIC 650 cc's , RC 550cc's injectors
2g head. 2g head machined to fit a 6 bolt bottom end. 1g/2g intake manifolds
some axles, (2g/1g fwd) fwd 2g flywheel.
rear 2g black taillights (go the car with these)
blitz blow off valve
greddy long route intercooler core with some pipes (2g)
Mustang Accufab throttle body with tps.
The Whole 1g (fwd) turbo eclipse. has engine,tranny wheels,complete susspension,missing turbo,and some other small things.
and there is some other parts,that i cant even remember. I was collecting these parts for past 7 years LOL, So its time for a shed clean up :)
WTB:
rear parking brake assembly (2g awd)
Are 2gb GS rear knuckles the same as the GST ones? If so, I could probably get a set of those. Need ABS holes?
Good question. There are a lot of part numbers so I'll have to call a dealership to confirm this.
Either way, I don't need ABS holes.
How much are you looking to get for the stock 2g head?
Im just going to throw this out there....I may not have the money to buy at the meet...but will be able to piece my list together over time....so if you dont sell it and have it when I can get it....AWESOME! :D...but here is my post from another forum :thumb:
Im just throwing this out there for now...getting some pricing ideas....If its a good enough deal Ill go ahead and get them from you.
I DO NOT WANT ANY GENERIC CRAP...that goes for ebay china crap too LOL..And I will do my research before I buy :D
List might get longer as I tear into this car :D
FOR: 1990 AWD TSI
I need an electronic boost controller
intake tube with one port for catch can S bends is a must
valve cover bolts(maybe or i might have to retap and go bigger)
Oil cooler not bent...I ###### can make one work from work so if you ask for to much Ill just go there LOL
Washer fluid Bottle pumps/motors
fuse box covers under hood and under dash
rear hatch lifts beat ebays pricing LOL
2g aluminum rim center caps
front bumper/hardware
GM MAF and translator
FS: 2G Alum rad w/ 2 12" slim fans, work perfect, no leaks
Spearco FMIC w/ piping kit & Authentic hks ssqv, no leaks
WTB: 2G SMIM
Box of random dsm bolts (alot LOL)
I'll have a custom 92-94 FMIC Kit, Big 16G turbos, 4-bolt rear with axles and cups,
used 2g wiseco pistons on eagle rods 20 over, new BC 280 cams, TRE AWD trans. with transfer case, there are so many parts stock and after market. I'll try to get a more complete list together. Let me know if your looking for something specific.
2g O2 housing - unported ~ $30
stock 2g radiator fan (plugs cut off) ~ $15
Marshall liquid filled fuel pressure gauge (1/8th NPT)~ $20
4 uncut bumpstops ~ $10 each
2g stock SMIC ~$30
2g stock LICP ~ $20
1g flange adapter for use with 2g stock UICP ~ $15
2g driver side speaker holder ~ $10
2g passenger side speaker holder ~ $10
2g FWD Outer CV boot replacement kit, BNIB ~ $5
Front and rear Prothane mounts - filled with industrial grade Polyurethane, front retains stock rubber bushing, rear does not. ~ $100
stock keyless entry - broken at keychain ring - $10
2g stock intake manifold - $30
EGR valve - entertain me
auto trans stuff - includes brake pedal, shifter assembly, shifter cable, ignition interlock cable, shifter cable bracket, and TCU, hollowed trans mount (ready for prothanes) - $150
5 speed shifter assembly - $20
6 bolt bare block. Got some grooves in the cylinder walls in 2 and 3. Will need to be bored. - $75
1g bare head - $75
2g stock cams - $30 for both
2g stock cam gears - $20 for both
Take both cams and gears for $40
2g rear upper control arms - $20
Apexi AVCR controller w/ harness (solenoid is dead) - $100
sunroof parts - frame, motor, etc (everything but rails) - B/O
infinity stock amp - $30
I'm looking for Evo 8/9 rotors and SS lines and 225-245/17 tires
Is there a place we can set up a table and canopy? This will be our first year so I'm not sure of the layout. Will I be able to get a trailer load of parts close to the swap meet? Thanks.
There's a grass strip between the parking lot and entrance road, or there's some lightly wooded area near the pavilion/grill area. You should be able to get the trailer in the vicinity, but will depend on when you get there, how many cars are there already, etc. Just remember, DO NOT park anything in the grass please.
I have a large list of items that I could bring to the meet. Some items I shall bring regardless of any interest here, other items will be brought if requested. All prices portrayed are negotiable. Tools are yours for any reasonable offer. (I am still hoping to "borrow," or trade for, an OEM oil pressure switch/sensor in any condition...and to purchase a reliable ball & spring MBC)
DSM Parts:
New LM-2 Digital Air/Fuel Ratio Wideband Meter Basic Kit #3837 (Single Wideband O2) includes LM-2 meter, Bosch wide-band oxygen sensor, 8 ft sensor cable, cigarette-lighter power adapter, USB cable for PC connection, weld-in bung and plug, LogWorks software CD, and quick-start guide, $230
LM-2 Wideband O2 Digital Air/fuel Ratio Meter
New Innovate Motorsports OBDII Cable for the LM2 #3809, (retail $25), enables vehicle 1996 (1995 for DSMs) and newer to connect to the LM-2, with cable you can log up to 16 OBD-II channels to your LM-2, measures 6 feet in length, $18
Innovate Motor Sports On-Line Store
Open Box 94-98 Eclipse/Talon Turbo 62mm BBK Power Plus Throttle Body #1750 (retail $250), direct bolt on in minutes, improves throttle response and horsepower, BBK throttle bodies are manufactured in the USA using CNC machined Aircraft T56 Aluminum, I bought this "open box", but I never used it, $190
New 95, 96 OEM right side (driver's side) reverse light, in its original box, includes lens, bulb, screws, and clips, $12
Used PTE Lucas 550cc fuel injectors, approximately 2540 miles on them, worked great when I recently removed them, I upgraded to larger sized fuel injectors, $110
Used ExtremePSI "Injen Style" Aluminum Intake Pipe painted black having recirculation tube (BOV return hose), and three more nipples (valve cover breather hose, boost control solenoid hose, evaporation canister hose), $60
Used 2g OEM fuel pressure regulator (FPR), from a 1995 GSX, $12
Used 2g OEM 4g63 valve springs and retainers, from a 1995 GSX, $10
Used 2g OEM A/T (Automatic Transmission) flex plate, from a 1995 GSX, $8
Used 2g OEM complete cat back exhaust (no catalytic converter included, only includes the resonator) where the muffler's dual chrome tips are in good condition, $offer
Used 2g (1995 GSX) upper timing belt cover, $30
Used 2g (1995 GSX) spark plug cover, $25
Used (almost new) 2g OEM driver's side motor mount insert with rubber side pieces, $5
Used Auto Meter Phantom 2 5/8" Mechanical Boost Gauge #5877 with assorted fittings and hose, $25
Used OEM Air Box and its OEM Filter that looks almost new, $12
Used Auto Meter Gauge Mounting Cup #2204 2 1/16" Single Pod in black steel in great condition, $12
Used Auto Meter Gauge Mounting Cup #3204 2 5/8" Single Pod in black steel in great condition, $12
Used TurboXS blue Standard Boost Controller with its original box, hardware, hose, and instructions, $50
Other Parts:
New LeBra front end cover #55466-01 for Ford Ranger 93-97 pickup (except Splash). Custom front end cover. Great looks that protect like a mask. $35.
Like new "wedge" cup holder, fits between the console and the (passenger's) seat, $12
Tools: (Please, PM me what to bring, otherwise my extra tools will eventually go to an Auction when my farm is sold)
Various pliers (regular, vise-grip, needle-nose, diagonal [wire])
Various screwdrivers (slotted, philips)
Various chisels (metal [cold], woodworking, lathe)
Various hand saws (woodworking [24", 12"/10" keyhole/drywall, miter], hacksaws [metal, bone])
Various hammers (hatchet, 5 lb, wood mallet, claw, framing, ball-peen, chipping/slag [welding])
Various clamps (C-clamps of various sizes, welding clamps of various sizes, pipe clamps [4 foot, 2 foot, etc])
Various plumbing tools (monkey wrenches, pipe wrenches, pipe cutters, etc.)
Various wrenches (adjustable [big to small], SAE [no extra metric], assorted Allen wrenches [all or none, in a container])
Various sockets and drives/wrenches (½", 3/8", ¼", SAE sockets, minimal metric sockets [no extra 10mm or 12mm])
Various drill bits (metal/wood [sets and individual bits])
Dial Test Indicator set (Starrett -15 0 +15 gauge and Enco magnetic base) in its box (the set was used with a lathe)
Craftman Toolbox with a handle 18"x9"x8" (missing its removable top tray)
Photography Items:
New Samsonite 1100 3-Section 54" 3-Way Pan Tripod
Samsonite 1100 photo/video tripod, extends 54", 3 section channel lockable legs, 3-way fluid pan, quick release mount, center balance column, rubber feet, $5
New Digital Concepts 58mm 2X Telephoto Lens
Digital Concepts 2X telephoto lens, 2X professional high speed auto focus/infrared compatible, deluxe super telephoto lens, high definition digital lens, digital advanced technology, high resolution day or night, multi-coated optical lens, anti-reflection coating, optimized for mega pixel, steel barrel design, heavy duty construction, includes carrying case & caps, lightweight of 5.5 oz., $8
New Opteka 58mm 3.2x AF HD² Telephoto Lens
Opteka 58mm 3.2x auto focus high definition² telephoto lens, platinum series, 2nd generation coated optics, lens bag, lens covers and instructions included.
Nothing changes the way you see the world like High Definition² and no company does High Definition² like Opteka. Opteka's glass optics define High Definition. Change the way you view the world. Enjoy outstanding detail, enjoy enhanced clarity, enjoy Opteka.
The Effects of Conversion Lenses-Since it fits right over your camera's existing lens system, a telephoto converter affects the zoom range of your camera's lens. A 3.2x telephoto converter virtually triples your camera's maximum focal length, bringing things over three times as close. Ideal for all types of photographic situations.
Improved Digital Imagery-An Opteka conversion lens can actually improve the image that your digital camera receives. By eliminating flare and ghosting, the ugly cousins of reflection and refraction, before they get to your camera's original lens system, your camera gets a much cleaner image to digitize. Plus, an Opteka converter allows you to use a more optimal part of your original lens system, resulting in crisper imagery. Check out compatibility at Opteka, $32
New Opteka 58mm .45x AF HD² Wide Angle Lens
Opteka 58mm 3.2x auto focus high definition² telephoto lens, platinum series, 2nd generation coated optics, high-index/low-dispersion optical glass, digital multi-coated, high speed auto-focus/infrared compatible, maximize day or night shots by providing maximum light transmission, built-in macro lens for extreme close-up shots, titanium anodized finish, sure grip technology, lens bag, lens covers and instructions included.
The Effects of Conversion Lenses-Since it fits right over your camera's existing lens system, a wide-angle and telephoto converter affects the full zoom range of your camera's lens. A .45x wide-angle converter virtually doubles your angle of view, allowing you to get twice as much in the picture. Scenes include more of the landscape, groups include more people, and interiors show more of the room.
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
