4GCS and 6g4b stroker
bowerboy_1
40
May 17, 2004
kyle, Texas
I heard that a 4g64 needs to be machined to fit into a 6bolt block is this true?
will a 4gcs or 6g4b crank drop into a 6 bolt without machining?
What will need to be modified in the block to stroke a 6 bolt over to 2.3l ?
Im planning on using crower rods and wiseco stroker pistons.
6-bolt 4G64 crank will fit in a 6-bolt 4G63 block.
As I've stated before:
IT'S THE SAME BLOCK EXCEPT FOR DECK HEIGHT AND BORE SIZE.
does that crank come out of the 89-91 sonata and galant or is that a different crank?
