4G63T parts on 4G63
The intake is identical, except for an extra port to connect the BOV to, so that would gain you nothing.
The throttle body is the same, except that the turbo one uses a bolt on elbow instead of having a hose slide directly on like the non turbo one -- so that gains you nothing.
The fuel rail is the same.
The airflow sensor reads differently, and the plugin is different.
The ECU is the same except for the tune and that there is an input for a knock sensor.
The best thing you could do to possibly gain a little performance, would be to get an EPROM ECU if yours isn't and get tune a chip for it, and get some reground cams. It it were me, I would switch to speed density and take out the airflow sensor, but keep the stock airbox -- no one would be able to tell unless they pull your air filter.
Is this like a hornet class dirt track racecar?
yes it is
what does the 2.4 come in and how will it help?
You would need to look for a Hyundai Sonata with the G4CS engine, as Mitsubishi didn't offer a car with a 6-bolt bottom above 2.0L in this country except maybe the Expo, but they are rare. How would they know if you had this bottom end in your car with your stock head? They look about the same on the outside I think.
yes would a 2.4 head gain me anything?
I doubt it, a Sonata head probably wasn't designed for max performance, although I doubt it even differs much from the one you have. The '94 Galant GS was a 2.4L DOHC 4G64 with ~160hp, but it being a 2G style head, I don't think you will be able to put it on a 1G block and fit it on your car.
Does the same not apply for insalling a 2g head from a 2.0 on a 6bolt block? Just drill the spots in the head to accept the larger diameter head bolts?
Kolby
  • Wanted 6 bolt NT water pipe
    • chrisman287
