(4G63 - Turbo OBD2/4G63 - Cyclone Turbo Engine only) what best suits a 98 eclipse gs
stark111
Jan 11, 2011
waukesha, Wisconsin
You will not be able to fit a 4g63 without extensive modification, way moe than its worth. You would be better off going with one out of an evo 8. At least that one would be sitting the right way(although its still a lot of work
Wow... might wanna do some research before throwing $1000 bucks on a motor that wont fit. IMO find a 420a 2.0 block to stick back in there. If your looking for a chalange google 420a to 2.4L swap. This uses the 2.4L 420a found in the cloud cars and pt cruisers NOT THE SPIDER. Good luck man.
