4G63 swap to CA4A
rapart
Apr 21, 2014
Gdynia, Europe
Hi all. My name is Paul and i'm from Poland. I just done 4G63 swap into 92 Mitsubishi Colt. Maybe word "done" isnt right cause i cant start it up. I have problems with wires so i think i have to ask some wisemen from here ;)
Ok. This is engine bay harness:
And there are two plugs from Colt i have to connect:
I found B-23 pin 11, 10 and B-22 pin 4 in 4G63 harness (c-59 pin 5, 6 and 2). For now i have these 3 wires only but i thought i can start it. I dont hear fuel pump is working and starter too. Any help with that?
ps. big thanks to 19Eclipse90 for his 1990 Engine Control Wiring Harness topic
I though that 100uF condenser is broken but i check it with multimeter and i think its ok...[DOUBLEPOST=1409848715][/DOUBLEPOST]I found that:
"Enter ECU Learn Mode :: 180F (82C)
Coolant Fan ON LOW :: 210F (99C)
Pull 1 degree timing :: 206F (97C)
Pull 2 degree timing :: 224F (107C)
Coolant Fan ON HIGH :: 224F (107C)
Enter Open Loop Mode :: 228F (109C)
Default Coolant CEL :: 235F (113C)
A/C Override :: 240F (115C)"
ECU Learn Mode? Whats that? Is this mean after install a new temperature sensor i have to get 180F to learn ecu a new part? Also, tomorrow i will put new wire from sensor to ecu and i will check a sensor resistance from this (correct for 1G 4G63?):
32* - 5900 ohms
68* - 3500 ohms
104* - 2700 ohms
176* 300 ohm
