4g63 n/a camshafts is upgrade?????
talontsiawd08
163
Sep 20, 2012
Chihuahua, Central America
I have a doubt, the first question is how to tell if the camshaft is a 4g63 n / to a 4g63t???
another question, I understand that the intake cam a 4g63n / t is different from a 4g63t
the car has better performance with an intake cam 4g63n / t
Thanks
Thanks
Not 100% sure what your meaning, but I wouldn't buy an n/t cam and expect performance gains, compared to an aftermarket cam.
I bought a 4g63 N/T head and They Came with camshafts N / T,
I want to know whether to use the camshafts N / T or better retain my cam shafts
I have understood that the head is the same, no problem with that
but I would like to know if the cam shafts N/T is an upgrade in a turbo car
There is no difference between the head of the n/t and the turbo. Intake cams are identical in their specs, the turbo exhaust cam has greater lift and duration than the n/t. There is no gain in performance by using either of the n/t camshafts
What do you consider "better performance" of the n/t vs. the turbo intake cam?
If you are having notable issues with the factory turbo intake cam, than it would lead me to believe that it is in someway damaged and not functioning properly.
