GSX_will
- 0
- Jan 26, 2014
Indianapolis,
Indiana
I have a '98 GSX that when I got the car had a tick/knock. So I ordered the JDM 7 bolt, same exact motor that was in the car except the Japanese version. Pulled the old motor and replaced it while replacing and relocating plugs and sensors so that it would work. We got to the end of the swap over and tried to start it, when we went to start it did crank and sounds like it wanted to start. We keep trying to start it to get fuel in the lines. It still would not fire all the way up
we tried to change the spark plug order from 4123 to 3214 and also tried starter fluid and still no fire. We also tried to reverse two of the CAS wires to see if that would work and nothing. We tested for spark and we found we seem to not be getting any at the plugs. We test the coils and they came back good I need any help and any ideas here I have been sitting and thinking on this off and on for a month now. Just wanna hear her run is all
