4G63 evo 8 crank vs dsm 7bolt crank
dawid4444
233
Feb 16, 2009
Chicago, Illinois
hey guys
i have a question
im building my block ( winter project ) and i need to buy new used crank.
and i dont know which crank to get evo 8 / stock 7bolt
i was looking for stock 7bolt crank but then i found some evo 8 cranks
ok so now my guestion
what is the good and bad thing if i would go with evo 8 crank ?
i know that the stock eclipse 4g63 7bolt crank weights 35lbs
and evo 8 crank is Lighter , weights 30lbs
thank you guys for help
i was under the impression that a 7 bolt crank was a 7 bolt crank? there was no difference.? i am also interested in hearing what the differences are.
yeah 7 bolt crank is a 7 bolt crank but the evo cranks are 5lbs Lighter
stock 7bolt 35lbs
stock evo 8 30lbs
so what is the good and bad thing having lighter evo 8 crank in eclipse ?
thank you
well it would have less rotational mass meaning a faster rev. and a possibility of high revving if its all balanced.
it'll be like having a light weight flywheel, to an extent.
Who told you that a EVO8 crank will work in a 2g block? They are still called "4G63"'s but there are differences. The big one being the trans bolts to the oposite side of the block, As far as I know the only pieces that will work are the rods/pistons in a 2g 7bolt.
i was thinking the same way but i wasnt sure
so whats bad and good things about it ?
LOL it wouldn't matter if the engine is 180* out, because the crank goes 180* out with the engine...so it will still bolt up to the trans.. unless I'm wrong?
you are not wrong
gixrman is wrong
7bolt crank is a 7bolt crank
dosnt metter if the trans is on the other side
it will fit ours block and rods with no problem
gixrman who told you that it WONT work ?
he is wrong cause it will
theres a lot of people here on this forum with evo 8 crank
i just want to know the bad and good things about it
you are not wrong
gixrman is wrong
LOL i thought i was.
the good thing will be the 5 lbs lost and the bad would be... well i can't think of a bad thing about using one. I'm sure it will hold up to power you may be looking for. so if it really is 5 lbs lighter then our cranks, i would say its just better then ours. so you would be better off using the evo crank.
just some more info on the subject.
http://www.dsmtuners.com/forums/newbie-forum/298272-evo-8-crankshaft-eclipse-2g.html
Thats like saying a 6bolt crank will fit in a 7bolt block simply becuase there still 4G63's. I have'nt personal inspected an EVO8 motor but i'm sure there are differences between it and the late model 2g 7bolt. Since your even going to have to flip it around and possibly spin it in the opposite direction which may cuase oil flow issues.
Ok, im wrong thats the first I heard of it. Good to know.
evo guys use the 4g64 crank(100mm 7 bolt crank)...and we use 4g64 cranks as well..so if the 4g64 crank fits in their blocks and the 4g64 crank fits in our block that means their cranks will also fit in our blocks..
the main difference is the split thrust bearing, which isn't a problem at all.
6bolt crank WONT fit in 7bolt block for sure.
evos crank are only 7bolt and evos crank will fit in 7bolt block 95-99 dsm
it wont fit in 6bolt block
this is a good Thread to read
ok great
ill just get the evo 8 crank
thanks a lot Alex7747 :D
Do you guys have any evo 8 crank for sale ?
or do you know where i can look for one ?
Because the one i found is sold already :( .
no problem.
i would try to find one on the evo forums. or you can try ebay, or craigslist. good luck either way.
have you looked into a stock 7 bolt crank and knife edging it?
yeah i found one 7bolt crank from 98gsx but after this Thread i would like to try evo 8 crank
and whats knife edging it ?
you mean grinding it down ?
Both engines spin the same direction. The evo block is just mounted opposite. I have compared both side to side, they interchange. Most aftermarket cranks for a 7-bolt dsm, and evo are the same part.
Manley Forged Crankshaft 88mm Mitsu Evolution EVO 7 8 9
Part Number: 190100 (Standard Stroke)
Manley Turbo Tuff Series Billet Mitsubishi crankshafts will feature uniquely designed, ultra-lightweight, fully contoured counterweights resulting in reduced windage and maximum performance.
Stroke: 88mm (Standard Stroke)
Weight: 33.5 lbs
Forged “Race Series”
For Street // Strip
- Premium heat treated forgings
- Special teardrop, diagonal oiling features not found on stock OEM style cranks
- Better performance at High RPM
- Stress Relieved & Shot Peened
- Nitrided
- 100% Magnafluxed
In Stock & ready to ship!
APPLICATION
Mitsubishi Evo III - IX Models
Mitsubishi Eclipse 7 Bolt (92' - 99')
Eagle Talon 7 Bolt (92' - 98')
I have a knife edged evolution 9 94 NM crank in my build it works just fine. If your going to knife edge a crank use your stock one the machine shop will just be shaving off the additional weight why spend extra getting an evolution crank unless u don't already have one
