+45mm offset?
eClipse Grindin
214
Oct 3, 2002
Oakland, California
Real quick question. Will a 17x7.5 (5x114.3mm+45mm) fit a 2g with at most a 2" drop? I was thinking maybe there is too much offset. The stock 2g GST wheels have a +48mm offset if I am correct but they are 16s. Will a +45mm offset be ok? What about a 17x8 (5x114.3mm+48mm)? Thanks.
the size of the rim doesnt matter it is the overall cirfumference. you can use 17x8 with a 45mm offset. The tire you want to use 225/45/17 that is the closest to the 205/55/16 the car comes with. Now if you want to go with a wider tire you might run into a problem :dsm:
  • Wanted 6 bolt NT water pipe
    • chrisman287
