235 tire on 18 by 8 with 45mm offset
kdrkmstp
124
Nov 4, 2002
Would 235 tire on a 18x8 with +45 offset not rub in the front wheels???
I heard that in some cases, the control arm would rub the tire or something like that.
Let me know if anybody is running that size tires on 45 offset.
thanks
I'm not sure about the front, but they are almost sure to hit the vertical link (aka spindle, aka knuckle) in the rear. Back it off to a +40 offset and you'll be fine.
- Jtoby
Well, I only have 2 of these, and wasn't gonna put them on the back.
And I was gonna put them on the front because the front ones are worn out unevenly...If I make it 40mm, I think it would stick out too far.
I hope it fits cause I got two of those for free :D .Well, let me know
if anybody knows for sure.
If they rub on the inside,, you can always run a thin spacer.
yeah i have 18 235 and its with a 42 offset and it almost hits so..a 45 will hit for sure..in the front..
  • Wanted 6 bolt NT water pipe
    • chrisman287
