EagleTalon24
- 129
- 0
- Jan 1, 2010
Seattle,
Washington
The sputtering is very noticeable when you are at a stop and start to accelerate.
When at idle, the idle will stumble down rpm and then come back up. I have taken it to a shop and they still were not able to diagnose what was wrong.
Here is what I have checked and a few things I have replaced.
plugs/wires
ignition coil
New MAP sensor
Cleaned Throttle Body
New PCV Valve
New TPS Sensor
New IAT Sensor
New Crankshaft Sensor
New CamShaft Sensor
pressure is around 40 psi
I am all but lost at this point.. The only thing I can think of is bad fuel injectors. Any advice would be apreciated.
plugs/wires
ignition coil
New MAP sensor
New PCV Valve
New TPS Sensor
New IAT Sensor
New CamShaft Sensor
