992GNTme
- 0
- Dec 14, 2008
florence,
Alabama
alright so i finally get my car out of my shop get everything done on it turbo-wise its running good i put about 3 miles on it start to go drive it home on the way it was driving fine other than maby a little bit of fuel cut well i boosted it up a lil it dosen't have a boost controller on it neither does it have a gauge but the turbo is only a t25 with a factory setting of 7psi so i figured it be ok till i get a gauge but anyways when i boosted it up it just had a pop it was more like a backfire but i got it home and saw that it had busted a water line that was the feed to the turbo well i fixed that and took a lil test drive and it was running fine besides going dead and not ideling so i left it alone for the night and went to take it back to the shop the next morning and it wouldn't crank i was thinking headgasket i took it all apart headgasket was good no bent valves timing belt was good and tight and pistons are tight but i still cant figuer out what the problem might be so any help would be appricated
