420A 420a removal questions
Brad Bell
202
11
Aug 15, 2014
Levant, Maine
Hey everyone, I'm currently in the process of removing a 420a from an automatic 2g eclipse. I've already removed the power steering pump, a/c compressor, wiring harness, and the radiator. I want to just remove the engine, not the transmission with it. Is there anything else that still needs to be removed? And what mounts to remove and locations of them. There's 4 right? Thanks everyone for your responses.
you're brave you can drop it out as i did. take 3 mounts out and use he tranny mount as a hinge. it hard to get just the engine out alone. pull them both out together. it helps installation if its together also.
Agreed. It is much easier to remove both still together. Makes putting it in easier too.
Also pull the harmonic balencer off. That will give you the extra space you will need.
