420a Race Car NEW SET UP for ZERO
DSM-ZERO
1,340
5
Nov 30, 2002
San Antonio, Texas
Hey everyone
This year im going to change my set up LOL
I know i know i just got the car running and i need to learn how to drive first BUT
Im in a really good posisition to do alot this year soooo
THANKS to my new sponsor Comp Turbo im going with a CT5 72mm
and im also going Air to Water
also
BIG THANK YOU to my Sponsor CLUTCH MASTERS for comming through on my new clutch for the season
Stay Tuned
ZERO
Good luck man I hope and wish you the best of luck. My setup has changed alot in the past months too. I know how it is so I just hope that you get the best out of it and everything works as planned.
goodluck with the build man.
care to share details on the a2w setup? core size, location, if your using a icebox/heat exchanger etc, circulation pump, resiviour location, line size/length etc, pump flow?
thanks.
So when did you steal my playbook Rob?!? Who sold me out on the liquid to air?!? I want answers!!! Good luck though man!
Me :D. A year and a half ago (though, I'm sure it was based on other things. Not just the fact I'm using it ;)).
gaaa make it harder for me to catch you LOL.
Keep in mind (and Rob would second this) we are all chasing after Hahn (10.87 lowest verifyable). Rob's sitting at 11.5 and I'm sitting at 11.4 (albeit both set-ups only came out last year. Both of us need to get past seat time and set-up problems).
There are still a couple in front of us; I know Crab is right around 11.2ish and AWDDynomite is in for an 11 flat. And just last month Cesar broke into the tens (10.99. Hey, a 10 is a 10 :thumb: Hasn't backed it up or anything, but he's there anyway). So there are a few out there.
But on the bright side, we FINALLY have a few out there :rocks:
MB
thanks.
Im using my same core just gonna weld some end tanks on it for the water.
core is a 6x12x12.
Im just gonna run and "Ice Box"
Resiviour will be behind the passanger seat or up front in aome where in the bumper
line size i belive is 3/4 and i have not decided on waht pump to use yet
OH im also running a NEW set of ID 2000cc injs for m Tony at T1's
PICS soon
everything will be done for the new season
that what i want to dooo but we will see how much room i have,...
Oh and Mark do you think an SRT4 trans will work with our motor.....do i need an adaptor plate.
Because i got a really good deal on a Dog Box
Well to answer your question no you dont need an adapter plate it bolts right up to the 420a motor. you just have to make a new tranny mount. oh and get srt axels of course and maybe spindles depending on what you already have
I would like to know more about this so called dogbox that you say you got a real good deal on.!
Good luck with that. Liquid to Air IC's use a different style core. You can weld on some tanks to the front and back of it to run water through where the air would normally hit the front of your core BUT, The Water Passages on a true Liquid to Air are smaller than that of the air passages. If you use a Air to Air core, you will lose efficiency. Here's a good link for a real one: Air to Water Intercooler
The website looks like something from the early 90's but their products are quality. They kind of explain why the Liquid to Air differs from the Air to Air but don't go into the science of it. You would think that the more water you can shove through the IC the better, right? Nope, because it's the water's heat absorbing qualities that you want, if you keep shoving the water passed the fins too fast, it won't have the time to evaporate to cool everything down. That's basically how it works. The cold water hits the hot fins and evaporates, dissipating the heat back to the Ice Box.
An Air to Air core will work but it won't be as efficient, as it won't be able to bring temp below ambient, which is why you want the Liquid to Air in the first place, right? Better than 100% efficiency? As much as I would like to discourage you from beating me with my own setup, that fact is obviously inevitable. So, I'll try to help instead. Here's to you beating Hahn's record this year.:applause: You've got the car to do it.
I can tell you its not a Rage dog box LOL other than that its a secret:shhh:
I figured it y=would work with an adapter plate.......But will see i might just stick with the NVt350 for right now....it has not given me any problems so far..I HOPE..
Well see on a new core im budgeting my self right now ...so i might be stuck with what i got..
yo Zero what all do i need to for my car i got a 60trim Turbo, wastegate and FMIC from a friend for my totaled GST. I need a part list im trying not to break the bank either so can i use stock injectors and just up grade pump or what. Im just gonna do 8psi for now
Start a new thread Hijacker.
    • Sdcryan1
