420a oil pan
If you don't come up with anything, a fabrication shop would weld you a bung on for cheap, probably less than you would pay for a new oil pan...
What is the advantage of having one that is pre-made over just modifying a stock one? I'm just curious? Are you afraid a modded stock one would leak?
well i actually had a angled brass fitting on it that i soldered on and when i put the return line on it cracked the solder and now it leaks so i was looking for one that was pre-welded so i wouldn't have to mess with a oil leak and a headache :banghead:
I would double check the OBX one for some reason I think I remember people complaining that the crossbar gets in the way on 2gnt.com but I could be wrong just giving you a heads up.
Yeah, if I recall correctly (and I'm a bit fuzzy on this, because I never really cared) the OBX pan is for Neon's.
