420A 420A A/C delete
I will be show you how to remove the AC off 420a .
This is just a how to remove the ac , I do not have information on the new belt needed or what size belt, how to tension the new belt ect. (I will edit once I figure that out)
shout out to those who helped me!
You know who you are!!
Step 1 is to release any pressure out of the system. ( this is illegal i believe, do as you will with this information)
There will be L and H caps ..
Make sure you wear gloves and a rag over while you do this so you don’t hurt your self! (Unless you had a leak like me and have no pressure then you’re lucky)
this is how it will look like
Step 2. Once that is done you can carefully unbolt these lines.
Two 10MM bolts on the fire wall.
Here are the locations
-fire wall (follow the L line)
Follow the L line and it’ll go to a canister. You can just unbolt these 2 bolts and it’ll come off
Now follow these lines again and it’ll go down to the condenser and you only have 2 more bolts and the lines will be almost free.
Now the only thing holding these lines in are connected to the A/C and same process, just 2 bolts
Now the lines and canister is free you can remove them.
Note: remove anything and unbolt anything holding down the lines, you will see them very easily.
Now step 3. Removing the A/C
There will be 4 bolts holding the A/C and I’ll show you locations
You can see the bolts on top are the bracket, don’t get confused!
The bolt circled in black is the bolt you need to get, there will be 4 in a square pattern! After the first just look over and you’ll see the next bolt. They will be pretty long.
The 2 bottom bolts
Once that is out you can remove the AC
Now technically you are finished but if you want to remove the bracket it’s just 4 bolts connected to the block , you will see them right there.
step 4. (optional) remove condenser
Very easy process just 2 bolts you need to unscrew with a wrench holding the nut.
left side and right side next to headlights
Now once you remove the bolts with a wrench holding the nut, you can remove the condenser and you should be finished! Don’t forget to unplug the AC sensor before pulling!
Tensioning the belt is easy. Get rid of the stock tensioner. The power steering pump will be used as a tensioner. It oscillates. With the bolts loose, use a pry bar to oscillate the pump until the belt tension is correct and tighten the bolts.
  • For sale 2g 2g front bumper corner brackets
    2g front bumper corner brackets. One pair and one right side bracket only. $25 and $12...
  • For sale 1GA DSM SIDE MOLDING TRIMS
    Buyer responsible for shipping. Had these for a while, as well some white side door moldings...
    • The_Partout_Spot
  • For sale 1G DSM W4A33 / F4A33 CONVERTER
    came off a healthy trans, won’t be using. Buyer covers shipping.
    • The_Partout_Spot
    Used Autometer Z series 52mm electric oil pressure gauge. Incluses sender, bulb socket, and...
  • For sale 2g DBW Setup/EVo3 Manifold/ DBW TB
    Have a full DBW setup that was used for a few days, going back to cable but can offer a discount...
    • Bedicine
