420 to 4g63
With the 420? How bout the gst? Think I’m going for it instead. Kinda want awd but damn it’s hard to find a good one without breaking bank twice
For the GST you'll need link instead of MS II, and I'd still upgrade the internals to be safe. I bet they could handle 400 crank hp, but to the wheels you'll need an upgrade. But even with the crank hp they"ll get fried after some time
Evo 8 uses the 4g63 motor its just designed so the transmission sits the same as the 420a which makes it a easier swap, there are a lot of people in Europe doing EVO 8 swaps on 2g Eclipse's! It is well worth it and it is really not that much work, you will have more work swapping in a 4g63t from a gst or gsx since transmission is on passenger side it will cause loads of fabrication.
I believe only minor things are needed for the EVO 8 swap with little to no fabrication
I follow Miguels DSM. It is NOT an easy swap. Custom drive shaft, hard to find EVO ? front axles, cut and weld front sub frame for tcase clearance and fab rear engine mount. There's probable other stuff that I'm forgetting.
I believe he was referring to the 420a->4g63t swap not the 420a->awd and 4g63t
Don't do this swap unless you really reallllllly want to. You'd be better off buying a car that came with the 4g63t. It is way less time consuming, way easier, and maybe just maybe cheaper.
You have my support if you want to do the swap, but I just recommend that you don't. Good luck with whatever though! :thumb:
Right.!
This is everything you need to make a EVO 8 swap with the 420a engine
MOTOR: -Evo 8 engine -Front,rear and passenger side 420a mounts - EVO HKS 272 cams - ARP head studs - Powder coated valve cover - Oil drain line gasket - Cam Seals - OEM Water pump pulley - OEM timing tensioner pulley - OEM timing belt pulley - OEM timing belt - OEM balance shaft belt - OEM belt tensioner - OEM water pump - OEM idler pulley - AC delete belt - Valve Cover gasket - Cam gear bolts - NGK BPR7ES Spark plugs - Mobil 1 Oil Synthetic 10W-30 - OEM Oil filter - Manifold Spacer - Rack and Pinon/Oil cooler bolts - Auto relay fuel pump rewire - SS fuel feed line - Evo 8 rear main seal
DRIVETRAIN: - 3g Eclipse trans (2.4L) -3G axles - 3G transmission plate - 3G lower transmission plate - 3G trans bolts - 3G motor mount bolts - Evo 8 flywheel bolts - 420a mount inserts - 3G trans mount - 3G slave cylinder - 3G shifter cables bracket - Pennzoil trans fluid - shifter cables 2g and 3000gt - 3G starter - 3G Clutchmasters Fx400 clutch - 3G Clutchmasters flywheel
GENERAL: - ETS FMIC piping - Turbo gasket - O2 gasket -Down pipe - EGR delete plate - Evo 8 alternator - Tubular manifold -Heat wrap - Maf/adapter - AEM intake -Punishment Racing FMIC - Greddy type S BOV - Evo 9 turbo - Evo 8 Mishimoto half radiator - Mishimoto Slim Fans -Fuel lines - Hallman boost controller - AEM Boost gauge - AEM Air fuel gauge -Fuel lab
FPR ELECTRICAL: - Evo 8 Ecu - Evo 8 harness - 420a Harness
FUEL: -DeatschWerks 415LPH High Flow In Tank Fuel Pump Kit Eclipse/Talon 420a fuel pump - FIC 1200cc injectors -Base Map/Tune
Just a basis of what is needed to do the swap from 420a to EVO 8 without a lot of fabrication (some fab still needed but not nearly as much)
Half of that stuff is optional. Also not sure why you included brands, as any brand of the same part will work.
