3inch intake on 14b
My dejon pipe came with a reducer ring and it was a PITA:cry: it kept on creeping off and I'd end up with a leak or wobbly intake pipe.
I took mine out and just tightened the clamp down. I have a Evo III 16g, but the compressor side diameter of the inlet isn't much different (if any at all) from the 14b. The worm gear clamps they send with their intake are good quality and I actually got it to pull down and the seal is awesome. Even did a boost leak test, after, and it held great. One other benefit is the rubber doesn't flex as much and it helped stiffen the intake pipe from moving.:D
