3000gt wheels on a 1g
they will fit on an awd 2g without rubbing...i dont know about a 1g though
the offset on 3000gt wheels is +46mm
I have 3000gt wheels on my 1992 a little grinding on the lower contol arm and a small wheel spacer was all that was needed for them to fit. If you don't want to grind you can use a slightly larger spacer but the may stick out just a tad. The wheels i have came off a 97 3000gt and were actually light than the 96 talon wheels that I took off. You will be hard pressed to fit any larger than a 225/50/16 in the rear without a large spacer.
