MGushard
- 12
- Oct 1, 2019
Santa Fe,
New Mexico
hello,
I’m a super noob to this forum as well as to these cars. I good friend had a 91 Talon 2.0 no turbo base model in storage for 5 years. Aftermarket headers, new cylinder head and other various new parts. I don’t yet know what 1G or 2G means. He handed it off to me to get it running again and use it and possibly buy it from him since a one car family aint working so well for us. I replaced the fuel pump and got it running then was told it needed a new cooling fan switch before it could be driven since the fans wouldn’t turn on after reaching a certain temp. I have a Chilton repair manual that came with the car, have researched online to find the part that matched the one with the broken white plastic wire/plug housing that lives closest to the top of the engine near the thermostat. There are 3 of these sensors in this same area facing the front of the car, 2 more below the top one.
OK, what I need to know that the repair manual, YouTube and other online research and parts stores have not been able to tell me is, exactly what each one is called and what they do... I think I know the top one is the cooling fan switch. Have no idea what the 2 below that one are or what they do. The second one down had tape on the connector, (which is an odd white plastic thing with holes on the top facing up) no wires attached and no loose wires hanging anywhere to be found that might connect to it. The bottom one has a 2 prong connector with a black locking plug, one of the wires was broken and disconnected so I removed the plug and reattached the wires using those spade shaped crimp connectors, but I am unsure which color wire goes to which prong on the sensor or if it matters.
I’m having issues with the temperature going way up after idling for awhile (I’m guessing it probably needs a new thermostat since it’s been sitting in storage outside for 5 years) the fans turning on, and the middle sensor of the 3 not being connected to anything and am desperately in need of transportation ASAP. It seems like a very cool car and I can see why owners of these cars have formed groups, forums, clubs, etc. I can’t wait to drive it.. any help I can get to understand the 3 sensors etc. on the coolant/thermostat area would be greatly appreciated. Even a picture with labels would be a big help, I believe I could figure the rest out if I knew which one was called what and how to wire up the middle one and to what. It seems like my friend might have been driving it without the middle sensor even hooked up so I don’t know how important that one is to get it on the road and me to work and back until I can figure it out. DSMtuners kept showing up in my searches so here I am, most likely a soon to be Talon owner. Thanks!
