3 inch cat to stock DP?
SinaiTSi
872
15
Aug 5, 2005
Misawa, Japan, Asia
I am planning on buying the 3 inch SS Buschur catback exhaust system with a 3inch cat. too. I just wanted to know if you can bolt the 3inch cat directly to the stock DP. Thanks a lot.
^ Correct. Most likely, a muffler shop can fabricate a flange to help you fit things together. Something like that shouldn't cost much.
I'm planning on doing the exhaust myself, so can I buy the flange online, or should I just go to a shop and tell them what I want.
Having a sharp transition down from 3" to the stock size is not a good idea. Ideally you would gently transition from 3" down to stock. A flat plate (flange) is a very abrupt transition and will hurt flow more than simply having a stock setup.
Are you saying that by going from stock dp to 3inch cat and catback exhaust, it would have less exhaust flow than the stock setup? And if so, what do say is the solution.
He's going from stock to 3" so it's ok but you're right, I would not recommend 3"DP to stock cat/cat back.
