2g's with GT35r
shaunp
115
4
Mar 11, 2008
Snellville, Georgia
I been searching and I wanted to know what kind of power the 2g guys are making, no stroker motors just 2 liter 7 bolt engines. Pleae No Drag ONLY cars.
I'm in the process of building my 98 GSX and I plan on running the 35r (unless something better comes along). The car will have occasional track and street use it will NOT be a daily driver. The hardest problem I'm having is deciding what type of manifold and turbine housing to run. I know its far fetched but I was hoping to make 600AWHP.
I want to hear from guys with a 35r setup, and if I'm not overstepping my boundaries a mod list and dyno #'s would be appreciated.
I'm going to be different and build the 7 bolt, I will be using a 1g head. Please, No why don't you just build a 6 bolt crap.
Here is what I have so far:
1g Head
Ross Pistons 8:3.1
Eagle Rods
HKS 272's
Crower Springs and Titanium Retainers
Fidanza Cam Gears
Arp Head Studs
Arp Main Studs
ACL Tri metal Bearings
SI Valves Nitrided
Ferrea Valve Seal
Valve Guides
Revised Lifters
I've attached my build list just incase anyone was interested. The manifold and turbo is not on the list for obvious reasons.
Thanks for all comments and suggestions.
if you do plan on going 35r no doubt the HTA from FP is the choice to go with. nothing but good reviews have been seen on many dsm forums. I myself planned on going 2.3l 3582r t3 t31 turbine housing, 4bolt. but once again changed my mind and am in the process of selling it, as i order the hta88 from FP.
parts look good! nice choices for sure. what are you planning on running for your fuel system?
mine:
walbro 255hp intank pump
walbro 255hp inline pump
-6an fuel line
pte 1000cc injectors
tuning with dsmlink
mine:
-6an fuel line
tuning with dsmlink
I might go with a aeromotive fpr, walbro 255hp, FIC 1150cc injectors and -6an fuel line from filter to rail and return line or I might go with the bosch 044 external setup.
I will also be tunning with the dsm link.
I'm running a 2.4 block with a regular gt35r turbo form the punishment kit.. im running a 255 in tank pump with 1000cc's and AEM EMS and meth injection
I'm sitting here dreaming of a 35r setup on a 2.3l. Good luck with your build shaunp.
