2G 2GNT Need Help With alignment (pulls to the left)
Brax93
69
Sep 9, 2012
lebanon, Ohio
Okay as the title says I need help with my alignment issue it pulls to the left pretty bad... as soon as I let go of the wheel its starts veering over to the left quickly, recently got new tires 235/45/r17 and got alignment afterwards I got them and everything was green except camber in the front and it was -1.00 on both sides so it was even, I was there when he did it and saw it on the computer... i just rotated the tires to see if it was tire wear but it still does it :confused:... also lowered on h&r springs/tokico 5way adjustable shocks. Also 420a.
Tie-rods have about 8 threads on each side.... and I checked all the bolts and look tight when I rotated them today... so if you have any ideas why its doing it would help. I don't wont to wear the tires out too quickly than they should.
I thought torque steer but after reading the post more carefully it sounds as if it does it always.
Cant remember the toe I forgot to get the printout when I left I might try and go back and double check and get print since its my friend and i don't usually get a charged but it was green except camber in the front... would a bad toe cause it to pull so bad if it was off by a little or alot?? and torque steer no it does it all the time when I let go of the wheel....
Edit: also i get some wheel hop when im not going fast at all could it be a bent suspension component?
