420A 2gNT Gear oil fill plug?
jjames_
Dec 6, 2021
Indianapolis, Indiana
I have a 98 rs eclipse just changed the clutch, cant seem to find the gear oil fill plug, i found a rubber stopper on the driverside tranny but i think thats for the trans fluid?
Gear oil and trans fluid, same thing. Are you unsure about something here?
Thats kinda what i was thinking was just unsure because i saw two drain plugs but only one fill plug
The 420a's manual transmission is the NVT-350. It does NOT take gear oil. That will cause damage. Recommended fluids are:
Mopar ATF +4
10w-30 high mileage engine oil
Synchromesh
And apparently Redline trans fluid... I've never used that one but I've used all 3 of the others in the past and can verify they work.
The fill plug is that rubber plug with the nipple in your picture next to the axle. I never use it though. I always remove the speedometer gear on the top of the transmission. It's underneath the air intake pipe and held in place by one 10mm bolt.
The NVT-350 holds 2.1 quarts of fluid. A long skinny funnel makes things easier. If you were going to fill through the fill plug you would need to add a piece of rubber hose to the end and run the risk of making a mess. That's why I used the speedo hole.
The drain plug is the horizontally mounted one. It's a good idea to replace the crush washer on it. You could just buy a magnetic drain plug and it comes with a new washer. The thread pitch is M14x1.5
I'd remove the speedo gear before draining the fluid. This will prevent a vacuum in the trans and allow the fluid to drain much quicker and less messy.
From the picture I can see that your driver side axle seal is severely damaged. I recommend replacing it since you'll have the fluid drained anyway. No since in filling it up with fresh fluid for it to leak it back out.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
