2Gers with 6bolt swap gurus..
rivet0r
490
Sep 22, 2002
I'm getting together the things I need for the swap, as my 7 bolt walked. The magnus site is pretty vague explaining what you need for the swap, I was hoping for something more detailed. If anyone has any tips from experience for me before I do the swap, that would be great.
I had a few questions about the swap as well. I plan on using a 6bolt block w/ my 2g head, but I heard I might have to have the bolt holes machined because the studs are different diameter IIRC. Is this true? Also, do I need to remove the cam sensor off my 2g head?
Again, any tips from your personal experience would be great, I don't like to blindly go at something and find road blocks.
-rivet0r
Originally posted by 98RedGs
Either/Or because honestly your going to end up with the same results.
Whichever one seems more like english instead of greek to you.
haha, sounds good to me. Thanks man, I appreciate it. I think i'm going to stick with magnus' way considering it's a lot more bolt in that RRE's way.
Thanks again,
rivet0r
