Resolved 2Gb CAS problem...
booster16g
Feb 2, 2008
findlay, Ohio
Okay so first It's important to know that I'm working on a 99 Eclipse 4g63. The CAS is on the passenger side of the block. At the end of the intake cam there is a piece that bolts to the cam that rotates inside the CAS. My question is does it have to be put in a certain way? Because one lobe is larger than the other, but it can fit into the camshaft either direction. Also what is the torque spec on that part?
