2G Turbo Upgrade Question...
paranoidTSi
1,608
Dec 27, 2002
none, Utah
I was curious to know if you can push a 2g into the low 13s using a 14b turbo? Or would it require more work than that? I'm on a budget..so a 16G is pretty much out of the question.
errr... yeah you can get a 14b you just need a j-pipe.. If you want to do a turbo upgrade I suggest you save up money and get one, or you will just end up wasting money and redoing it again later.btw, even with a T25 you should be able to get into low 14s.
