2g throttle body in 1g
kwAlk23
82
Sep 9, 2006
Palm Harbor, Florida
I have a 90 talon with a 6 bolt/2g head. I had the 90 TB on the car but it was a massive leak. When I put my 2g one on it, it ran perfect, but I don't have the TPS hooked up. Is there any way I can hardwire a 2g sensor into the 90 sensor to make them work?
Also I don't know if you are worried about performance any, but the 2g is like 8mm smaller in diamater.
First off, why would you even put on a 2g intake manifold and 2g throttle body ? Both are smaller than the 1g pieces, that's just a downgrade in itself. Get a cheap 1g tb on ebay and connect the 2g elbow and if you can get a 1g intake mani and slap that back on as well. Unless you really don't care about making power... Just my .02 on it.
Ok first off, This was the motor that was in my 2g. It is a 6 bolt block with 2G HEAD. Your telling me to put the 1g intake manifold on the 2g head? Yeah that will work perfectly right?:notgood:
If I were to find a 1g throttle body then I would have to port it out a little to match up with the 2g IM. I'm asking if I can hardwire in a 2g throttle body on a 90
yes :D
You could hardwire it but i wouldn't recommend it. And FYI a 1g intake manifold would work fine on a 2g head with a little porting on the runners on the head to match up. Research my friend.
