97FairGame4g63
- 0
- Jun 28, 2015
orillia,
ON, Canada
Hey I bought my car used in June. It's a 1997 GST with a built bottom end stock head 4g63. The car has 95 eprom ECU, FMIC, Evo 3 turbo and manifold.
The car also has a 2 step but I'm not sure how it's set up and I don't know where to start looking. In first gear if you pull away like normal it's like he car is trying to do a 2 step at just over 4000 rpm while it's moving. The clutch switch isn't hooked up and I see a couple wires spliced in. When I connected it the car wouldn't crank over at all so I left it. I'm just not sure if someone installed a WOT box wrong?
