2G Spyder Speaker Grill Removal
If I remember correctly the mesh is just wrapped around the back of the door panel hole? So I would take a pair of needle nose tweezers and carefully unwrap them from the back.
Don't quote me on that though it has been awhile since I upgraded my speakers, I have the memory of an 90 year old man
Mine were screwed into my door panels when I upgraded my speakers. Maybe that was from a previous owner, but none-the-less you will need to remove your door panels either way so go ahead and do that. It should be self explanatory from there.
The black ones I have seem to be have some plastic tabs but I'm not sure. I didn't see screws back there or it being wrapped. We're talking about removing this right?
One of the grills was glued on (someone beat me to it) and came off easily with some pressure. The passenger side panel was untouched. Due to the lack of heat, I decided to just use pliers on the two tabs and freed that portion of the plate. The rest of the grill was taken off with tugging in different directions in order to weaken the tabs. Both grills show no signs of deformation but their is probably a much better solution for someone who isn’t in a rush.
