2g slave cylinder restrictor
talon55
119
Jun 13, 2006
somewhere, New York
My clutch grabs to fast soon as i release a little it starts grabbing i think thats the cause slave cylinder restrictor. I was reading the froum and i came by that. Whats does it look like anyone got a picture. And how can I get a another 1.
Tanx
follow the hard line comming from the slave cylinder that goes to this metal tube on the tranny,you cant miss it,personally id take it off and just go with a stainless steal clutch line,if its grabbing to fast you may need to adjust the clutch rod underneith by the clutch pedal
Make sure your clutch swith isn't adjusted too far down. It can limit how far your pedal comes up, which limits your pedal travel. If you adjust the switch to gain more travel, don't forget to adjust the rod on the master afterward. You want it set where you can push the slave back in with your fingers, but so if you adjust it one turn tighter, you can't push it back in.
