MITSUMURDOK
- 150
- 8
- Jul 12, 2005
Newburgh,
New York
Ok, here's the deal. My 95 TSI AWD stopped going into gear while it was running all of sudden. I changed the master and slave cylinders because both were leaking and bleed the system correctly. Still no change. I thought maybe a bad TOB. I got a new clutch and all related parts because I have no idea what is in it now or how old it is, so I figured it would be best to change everything. Today I started taking it apart and found out that one of the bolts on the shifter bracket (the one that bolts to the trans and the cables clip onto) is missing. I think now that this is what caused my problem from what I've searched, would this be correct?
My question now is do I put it back together and see if I have gears, or continue with the clutch change for piece of mind? The biggest factor here is the cold weather. Sorry for such a long post, just need some advice.
