2g manifold on 1g + cost
vinnybean
72
Aug 12, 2006
Methuen, Massachusetts
Hey guys i looked for this for a while but i managed not to find the anwsers i am looking for.
i have a 1G gsx and i found a 2g manifold and o2 housing. Will these bolt right up with no problem and if so how much are they worth? thanks
Vinny:coy:
i have a 2g on my 1g gsx...90 it bolted right up.. no probs. only tricky gettin the DP back on. i didnt have todo any cutting.
Dont be scared off by the grinding to make it fit, took me 5 minutes with a Dremel. Something to really watch out for is the studs and the possibility of breaking them off. If they are the stock ones, might want to see about replacing them. Be sure to hit them with a VERY ample amount of WD-40, Liquid Wrench, or PB Blaster and letting it soak in good prior to working on it. Good luck to you.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
