2g KYB AGX Shock issues?
my98GST
1,045
21
Jun 1, 2005
Cleveland, Tennessee
I heard a while back that the AGX shocks had some issues with the shock body being roughly 2" too long for 2g's. Have they fixed this issue or should I just hold out on some Tokico Illuminas? I'm running tight on cash and I desperately need some shocks....
Vallary99 said:
I run KYB AGX on my 2g GST with no problems.
It looks like your still at stock ride height? There's only a problem with the Agx's when the car is lowered. Did you happen to compare the agx's with the stock shocks when you installed them? To the origional poster is you car lowered or do you plan on lowering it?
I have run AGX's with lowering springs on a 95 GST and didn't have a problem at all.
I have a set of skunk2 coilovers that I intend using with the AGX's. I'm only looking for an inch drop
Same here. I've had them on for a little over 2 years without a problem with a 2" drop.
daren_p said:
Well it looks like they've fixed the problem with the agx's according to the posts. Has anyone actually compared the agx's to the stock shocks as far as height goes?
I didn't compare them but I did get the adjustable KYB AGX's if that makes a difference.
