2g J-Pipe for ETS super short route
rvernsey
Oct 5, 2019
Punta Gorda, Florida
I am 0 for 2 on J-Pipes thus far. I have the FP one that came with their install kit but for my application it interferes with the mount on the crossmember and really travels too far 'left'. I also have the "ETS Style" one that comes nicely over the top of the turbo but interferes with the condenser fan big time, without even room for a slim fan. Is there a J-pipe being produced right now that is like the old Dejon one that hugs the turbo tightly? I did a lot of searching but posts are from 10 years ago with half of the companies not even in business any more.
When I had a 16g this was the best one avail. The only thing is you will have to find a used one. You are either going to have to make one, modify one or buy a quality used one like in the picture. I think this was a old desighn ets pipe.
The best fitting J pipe that is readily available, that I know of, is the CX Racing J pipe ( same unit that came with the Punishment Racing kit)
Fits just as you are needing it to, allows for fans and doesnt take a dumb path
they are 50 bucks
The old stainless Slowboy Racing j-pipes dropped down right between both OEM fans if I remember correctly...or maybe you only needed a slim fan on one side or something. It's been years since I've installed one and definitely haven't seen any for sale for quite some time. I have a couple but they're not going anywhere for this reason.
yeah I wouldnt sell those either
The piece I mentioned above follows that exact path and fits great, but does have that goofy cut & weld to make the tight bend
Unsure what J-pipe I have I thought it was the stock one for 14b but I can't remember off the top of my head how long it is compared to mine. But I use Short route FMIC and have no clearance issues at all, I have a ton of extra room that being said I also run pusher fans on the other side.
These are the only pictures that I have.
