ECMlink 2G issues with stalling and ISC at 46
PrimerPLus
1,160
20
Jul 28, 2011
Tokyo, Asia
1). Any boost, vac, or exhaust leaks?
Boost leak tested 5psi above your max boost with no leaks? tested to 30psi no leaks
2). Verified mechanical timing?
2g verified with ecmlink
3). Verified base timing?
2g ecmlink
4). Ignition system
COP or Stock Coil:stock
Wire brand and Age:ngk 2days
Spark Plug brand, type and Gap: ngk bpr7es gap .025"
5). Motor health (Compression Test)
not recently
6). Performed basic throttle body adjustments?
Idle Switch: might be an issue as its a rebuilt 2g throttle body
Throttle Cable: yes
TPS: .63volts
BISS: this is my issue
7). Compression ratio
not recent
8). Any known bad sensors or brittle wiring?
yes evap
9). Any DTC/CEL codes?
evap rear o2
10). Electrical system
Car off (not running):
Car running:
11). Base fuel pressure and injector values
Base Fuel Pressure: 42psi
Injector Size (cc/min): FIC 1150cc
12). Properly calibrated and configured wideband sensor
Sensor Brand: aem uego
Calibration Date: 12/20/15
13). Type of fuel
Type: 90 octane
Percent of Ethanol:
14). Watched ECMlink how-to videos? yes
I am trying to get my car ready for a tune but I am having some issues and I do not know if it is because of Speed Density setup or what.
Car idles fine startup and it idles about at the rpm I want.
My issue is this, when trying to get the ISC in range say to 30 it will not budge. The lowest I can get it is to 46 and it seems to be stuck at that, unless I give it gas or turn on headlights etc fans kick on and then it will change to a higher number and then bounce around and when those go off it will drop back down to 46.
Also, while driving when coming to a stop, or backing up, it will sometimes stall unless I give extra gas. It will even stall if I am say at 4k rpms and let off the gas while in neutral, the RPM's will fall dramatically below 1k and sometimes stall out or recover. Also, while headlights, radio and heater are on the rpms will drop not enbough to kill it, but enough to notice.
It is really annoying and could be potentially dangerous.
I sent in my ecu to be evaluated by The guys at ecmtuning. They gave my ecu a clean bill of health and said there is no issues with it. I replaced my ISC with a brand new one, and I am still getting this issue( which is why i am writing this).
I am vented to atmosphere. Using Tial 50mm bov, mods are up to date. Maybe this is my issue I don't know.
I read that the FIav could be an issue? or the SAS screw on my throttle body? Maybe since its a rebuilt one it is not set properly?
I have not adjusted any speed density values or timing or fuel tabs because I was trying to get this ready to be professionally tuned but he will not do it until it is 100% which I understand so I am trying to get this done, just need some guidance / help.
Here are 2 logs from tonight.
Looking forward to feedback.
