2G interior/exterior questions and suggestions
simoniz
50
Nov 8, 2003
Inertior question:
I have been searching for the blue glo hvac,but no luck.The hvacs glow all in blue at night.please leave me a web site?
Exterior question:
Buddyclub2.com is making a bluddy club2 wide body for the newer generation imports.I called them and they told me they are not going to make one for the 97-99 eclipse.Maybe if i get enough positive feed back on this post i can try to convenise them to make a wide body for the 2G eclipse.What do you think?
Well, here is the best thread i could find:
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=5282
I'd check eBay for an replacement hvac or kit. If you want to do the work yourself, remove the hvac and replace every bulb with a blue LED. (don't forget to use a resistor to drop the voltage, otherwise you'l have a broken LED instead).
You can find this at your local RadioShack:
276-311 BlueLED
271-1113 5pk of 330 Ohm Resistors
I wouldn't use more than a 15watt solderring iron.
276-311 BlueLED
I dont think you understand me.Im looking for a overlay that all of the rings glow blue.i have seen it on a website,that i cant find any more.
They have the hvac glow overlays all over ebaymotors for $14.95 +
IMO I would just get the plain white overlays that dont light up and do the l.e.d.s
