2G 2g How hard to take off wing?
Depends on which wing(s) you have.
I had the turbo high spoiler and it took 4 bolts and strong arms to pull the glue apart. Total time, less than 5 minutes. Make sure you know a body shop that can patch up the holes for ya cuz if it rains it will be all over your interior.
Gus
He said he's talking about a 2Ga (95-96). Thumbnail.
-Pop the hatch.
-Pull the interior trim panel off the underside (it's clipped in - start at one edge and work your way around it, pulling firmly, but gently).
-disconnect the harness to the 3rd brake light.
-Use the proper socket to pull the bolts out from below. It's either a 10mm or 12mm.
-Lower the hatch and start pulling upwards on the wing. :thumb:
I took mine off, as described in the previous post, and what you'll find when you're done is the holes from the bolts which will need filling/painting, a large grommet from the brake wire that would look a lot better filled/painted over and some residue from double sided tape on the edges of the wing as it comes in contact with the back of the car that will have to be removed.
I do like the look without the spoiler though, so I think it's staying off.
