2g HEAD ON 6Bolt Block
sakrafice
217
May 28, 2003
Sumpter, Michigan
I hope i get responces this time around.
I got a 2g head and a 6bolt block with stock internals (big rods,1g pistons,crank)
What i want to know exactly is what will I be running into getting this to run correctly?
Ive looked into the swaps but they never really discuss running a 2g head; I figure id be a better way to go for me for 1. In college and have little money to work with (and have a 2g head laying around). 2. According to mangus just gotta swap some plug wires around and maybe a couple other stupid little things. I also know ill need to drill the holes a bit bigger.
Any help would be greatly appreciated.
Drill out the holes for the studs is all you need to make it bolt on. Since you are a 2g you will also need to do the typical 6 bolt swap stuff. That can be found a million different places though. The head itself will be fine though. For what its worth I am putting a 2g head on my VR4 and it only requires drilling the stud holes and mounting the cas. Also has to be ported to match the 1g intake, but you are 2g/2g already so thats fine.
