2g gsx Tuning input
Eclipsekustomizer
35
Jan 26, 2012
Marietta, Georgia
I need some input about tuning. I just built a motor with H beams and ross 8.3 TO 1 pistons and at 18 psi im barely making 200 hp, i have fp ht68a turbo FIC 850s FMIC FP intake and link V3 oh and 255 fp. I have advanced my timing during WOT to 18 throughout my pulls and i still have no knock, should i advance more or up the boost i only want about 300 but in my gst i was making 300 at 18psi and my timing was like 10 throughout WOT any input much appreciated im getting frustrated and afrs look good:confused:
How are you only making 200hp with a "built" motor,and a 68hta?
You should be at least 25 psi on the 68hta with a "built" motor,and more fuel.
Post up some wot logs.
i hope i did this right
let me know if you guys can read that one and ill post an accurate one tomorrow
Ok before 439 seconds.I see only 40% throttle position.And 2 something hp.At 438-439 seconds I see TP at only 86%,and less than 175 hp,but 220 tq.
So most of the link is at idle,And I did not add load% to my screen.And the highest rev I saw was still under 6k.
The 20 psi post was a test this is my actual current tune any adjustments or pointers much appreciated
so i guess i need to bring it up to atleast 6k on my next log. Will do and ill post it tomorrow thanks guys. Any advice on the timing should i advance it more or is already to far advanced?
