2G 2g gst fuel lines
903_DSM_GST
Sep 20, 2023
Athens, Texas
I have a 96 gst and im in the process of getting it running and i need some suggestions with fuel lines because my stock line has a hole in it and what brand should i use for aftermarket lines
Length, brand, fittings
anything helps
You could either purchase this kit or buy some of the parts they use and make your own kit:
is there a way where i can get my stock fuel line fully out of my car with out dropping my subframe
I've never worked on a 2g, but on the 1g you don't have to drop any subframe. I'd be really surprised if you had to on the 2g.
i went under my car last night and my fuel lines run in between the body of the car and the passenger side subframe and is there a way to fully remove the lines and filter without dropping the subframe
  • Wanted 6 bolt NT water pipe
    • chrisman287
