2G 2g ground wiring
If your talking about your battery, and if its mounted in the engine bay, I'd run two ground wires off of the negative battery post. Both wires should be 4awg (american wire gauge) from your negative post send one 4awg wire to the engine and ground out at a engine/tranny bellhousing bolt. The othe 4awg wire off of your battery send down to the frame (thickest square tubing part under your hood)
