2g fwd Fuel trim malfunction??
blackhawkgsx
250
Mar 6, 2010
Miami, Florida
Hi i have searched for a definite reason as to why I keep getting a fuel trim malfunction code and didn't have much luck . after looking over my car for any thing that was wrong such as leaks cracks , ignition /fuel problems but only thing i came up with was a blown turbo and a hair line crack on my manifold !! so could the crack be causing this code?
the car also idles high when this code is on if i clear the code then the car idles fine.
if it helps any the car is a 95gst with 6bolt bottom end ,e3 16g e3 ,ex mani, smic,wally 255, 3" tbe no cat. I do notice when the cel is on my afr's drop to 16.9-17.5 at idle and some time between shifts go to --- other times between shifts it goes to 12-13 on my wideband ?
any one else have this issue?
iirc the code is p0170 correct?
this code can be caused by a bad o2 sensor or in your case a exhaust leak before the o2 sensor.
by chance are you running e85?
No e85 ,93 octane and i just replaced both o2 sensors after a buddy of mine told me to get rid of the bosh sensors i had , so i took back the bosh and exchanged for the denso sensors. when i did that i did notice the afr's where richer .
So you say the crack in my exhaust manifold would cause this then? So time for a new manifold?
Its just a hair line crack and i only noticed when i took the manifold off to install ss oil feed. On the collector on the inside a piece if the manifold broke off went through my turbo & every thing:mad: now i have mega shaft play:notgood: the crack is huge on the inside it looks like a spider web, but on the out side you barely see it ... so whats a good cheap manifold i can get , im low on funds after fixing most of the half ass work done to this car from the previous owner . Also thanks for the input guys!!!
