1G 2g fans on a 1g radiator?
forcefed86
1,007
14
May 23, 2006
wichita, Kansas
Local 2g is parting out and I wanted to know if the 2g e-fans are a direct bolt-on to a 1g radiator?
i know that the size of the fans i beleive are the correct size you could measure.. i dont think the plugs are the same.. 2g's have 4 wires cause there are a 3 speed fan and i think the 1g's are only a 1 speed fan.. only 2 wires.. and i dont think the plugs will plug into each other.. another common factor you need to look at is cfm flow rate.. i know the 2g's flow 1630 cfm i do beleive.. and i do not know what the 1g's cfm flow rate is.. and or the width of the fans themselves to hows close you would come to the turbo something else you would have to look into .. i think the best bet to this questions is to find out flow rates see if they are comparable and then actually try one to see the fitment and let us all know..
Not worried about wiring. I'd need to know if the shrouds bolt up to the mounting holes on the radiator.
thanks!
