2g exhuast manifold on 1g head
It should work just fine. Alot of people use ported 2G manifolds on 1G heads. Bolt patterns are the same.
Yeah it will work here is a link that shows how to port it and what it takes to install it on a 1g http://www.vfaq.com/index-main.html
Just go to the porting and select the 2G manifold and it will show you how it goes on and a few minor modifications for it to fit.
Was running it as well for a while, worked good till i went with a new set up.
2G manifold does have bigger ports as well.
Like everyone said it will work fine. But what you need to do is grind down a little bit of the bottom right hand corner of the flange that connects to the head. So it can fit in perfectly.
