Resolved 2G Do I have the wrong struts?
Tortuga
May 17, 2023
Texas
Swapping out my coil overs for a a factory strut assembly, this looks like too much distance between the bolt through. Am I suppose to force the strut that much of a distance? I bought them off eBay from a GST, but it’s like a 2” difference in length
I’m an idiot thanks! Also do you happen to know which way faces in towards the car, the longer side or shorter?
Raised the other side, it’s still off by almost the same amount.
Removed sway bar and it dropped instantly putting a socket on the control arm bolt. Whew that only took me 3 hours for one side
You'll note that the post is tapered and so is the shock mount. If you put it on backward it won't go all the way on.
