m_0ney_pit
- 819
- 87
- Jan 12, 2007
Easton,
Pennsylvania
Does anyone make a carbon fiber front strut tower brace for the 2g?
I was interested because of the possible weight savings wasn't really thinking about performance. I was thinking if I'm adding something something that could add 15-20lbs wanted to check if there was a lighter alternative.
Tower bar made from solid bar stock?
Why don't you just get a real tower brace that's functional and wrap it in fake CF? There is no way that CF would hold all that tension if you actually wanted functionality.
15-20lbs?
.No thanks...
Anyway, some properties
Carbon steel
Tensile strength - 840 MPa
Density - 7.5 g/cc
Aluminum (T6, no most companies probably won't use this)
Tensile strength - 480 MPa
Density - 2.6 g/cc
Carbon Fiber
Tensile strength - 1600 MPa
Density - 1.7
Besides the fact that CF has twice the tensile strength of carbon steel, a hollow tube that is 1.5" Diameter with wall thickness of .12" and length of 3' will weigh about 5lbs in steel, 1.7lbs in Aluminum, and 1.1 lb Carbon fiber. Please check this to verify for yourself.
Now will the aluminum bar be hollow, no probably not it will most likely be solid so the weight would be closer to 6 lbs. Also the elastic modulus is very close to steel with the fiber direction.
Facts are true. This is my view on it from my research, whether its true or not:
CF has a bunch of strength but CF is weak when it comes to compression\tension which is what a strut bar is fighting to do. Im sure it will work and perform better than stock but, not better than steel or aluminum, steel would be ideal for functionality. Your best bet would be to have an aluminum core with real CF wrapped around it if you really want the real CF look and it will be a tiny bit lighter.
When the piece is in compression ...
