2G Boost Leak Tester Noob Help
ireallylikedsms
Jul 8, 2010
Flin Flon, MB, Canada
Im about to build a boost leak tester and test my 96 talon tsi awd. Ive read up on it/seen vids of other makes and get the gist of it. I know its super noobish of me but could sombody tell me all the steps involved? And the most efficient materials? Me and my beloved dsm would appreciate all the help we can get
Get a cap,drill a hole,put in the valve stem get a lice of PVC the size of he I'd of the coupler you will ve using,use purple primer and cement on the inside of the PVC cap and the outside of the little PVC pipe and push the pipe in the cap. Put in on the car and fire up the air compresser. Listen for leaks and fix them. You are done. Lol
or save yourself the time and hassle and get this. $25 for a boost leak tester with a gauge so you don't have to have a friend make sure you don't over pressurize is a deal.
edit: (just saw blackjet18t suggested the same thing)
