force_feed
- 323
- 5
- Jan 31, 2008
Katy,
Texas
Whats up guys?
I have a problem on my hands, and not sure what the deal is here. I was given a job that I should of refused, because I knew it was gonna be a hack job.
Background:
I was to put a motor into a 94 N/A Eclipse. The motor that I received was a 2g turbo block. I called the guy up and told him that this wasn't going to work like it should, he needed to get the correct block. The guys tells me he knows it will work, so do what I can.
He also wants me to not install a belt on the front balance shaft, because he heard that they have the potential to fail. I informed the guy that he is mis-informed, and the rear balance shaft fails due to bearing failure. He doesn't want to hear it.
1st Problem:
I realize this car is a big HACK job. The driver side motor mount has had the bolt holes wallered out so they will line up, and the studs were bent to wards the head. WTF??
2nd Problem:
I get the car together and start her up. She is running really smooth! All of a sudden the T-belt is slinging oil every where. I kill the car fast, and start pulling all the accessory belts off. I soon realized that I forgot to put a bolt in the oil pump housing that went to the front balance shaft tensioner. My bad...shit happeneds. I get that plugged up and wanted to make sure it wasn't going to leak, so I throw on the harmonic balancer and start her up again. This time no oil, so I put everything back together.
Major problem:
I get everything put together, start her up. After a few I go wash my hands and go to the restroom while the car is running. I come back out and the car is pouring oil again, and making a weird sound (sounds like balance shaft bearing failure).
Any idea's? I'm about ready to call this guy and tell him to come get is crap!!
Background:
1st Problem:
2nd Problem:
Major problem:
